Trailabite
Anyone running gears lower than 5.38's and driving on the street? Do you love it or regret it?
This is for my Jeep/Truck project. It's mostly going to be for rock crawling but I will occasionally drive it to work on a Friday or to take the wife to Cold Stone for some ice cream or San Diego for some seafood. lol. Maybe, get on 400 for one or 2 exits. I'm looking at running 6.17's maybe 7.17's with 42" tires. With the over drive gearing of the 700r4 running at 55mph doesn't seem to be too bad according to the calculators.
Fixed
I ran 617 with a 350/205 with 44's in my Jeep . For the mountain but I did drive it on the road some6.17s would be perfectly fine with a 700r4... They would be **** with a 350
How hard did you drive it on the trails? After more research it sounds like the pinion is small, as in less contact with ring gear and people seem to break a lot. I may just stick with the 5.38 gears, that seems to be a common setup.
I am pretty sure i would break a 6.17 coming up my drive way. I personally think a 5.38 would be a much more reasonably option.
It's no bouncer but It was beat on it plenty hard . Jeep was built around 06 most people I knew then ran 617. With that being said what I've learned now and that I make more money now an atlas and higher gears would be the way I would do it.How hard did you drive it on the trails? After more research it sounds like the pinion is small, as in less contact with ring gear and people seem to break a lot. I may just stick with the 5.38 gears, that seems to be a common setup.
Ive run 6.17s 39 krawler with a 4.0 AW4 trans combo in a Cherokee 75mph on the freeway no problem roughly 26-2700rpm the OD ratios are very close between a 700r4 and aw4Anyone running gears lower than 5.38's and driving on the street? Do you love it or regret it?
the tooth count is not as big of a deal At any given point you only have"x" amount of contact A 9 nine 6.20 pinion is like 6 tooth but the teeth are fat compared to a higher count pinion i have smashed my 400 plus HP moonbuggy into backdoor smoking sticky trep 42s full of water with Dana Spicer 6:17s ive shattered spidertrax units {old ones} 300M rcv 35 spline inners but no R&PsYeah for gear strength, I wouldn't run anything lower than a 5.38. There's still 8 pinion teeth and 43 ring gear teeth on a 5.38 where as a 6.17 pinion only has 6 teeth and 37 ring gear teeth. So obviously, the lesser amount of teeth on the pinion puts a larger amount of stress on the ring gear during load.
