454tbacon said:
What does LS stand for, I never knew,just curious.
I don't think it stands for anything. LS1, 2, etc is the RPO code for vehicles that came with that engine. All the Gen III / Gen IV engines have just become known by that nomenclature because they share the same architecture though. For instance, LQ9 is the RPO code for the high output 6.0 iron block engine, LQ4 for the lower output 6.0. Most still refer to them as LS engines though because the blocks are nearly identical, all the same parts fit, and most everything is the same compared to a true LS engine. All TRUE LS RPO codes have aluminum blocks though. (LS1, 2, 3, 6, 7, 9. They even have an aluminum block FWD engine cousin that is an LS4.)
And these engines aren't just all high end power. Look up some of he stock dyno graphs for the LS engines. The torque comes on just as early and strong as the big blocks. That's why everyone compares them to them.
I'm not the one who determined that BBC's are obsolete, GM did and stopped making them as a result. You think it was just to look good on paper? You think if they replaced it with a **** engine their customers wouldn't notice and stop buying vehicles? You think that's a decision they made lightly? Like some dude just showed up to work one day and was like, "You know, to really **** with our customers we should stop putting good engines in our vehicles and instead put crappy ones in. Ones that are super cheap to make and don't perform at all. But we'll tell them that they are awesome and they'll never know the difference!" And then everyone else there was like, "Hey, good idea Bob! That'll be hilarious!"
Why do you think GM is STILL the king of production V8's? Why don't you see thousands upon thousands of modern Ford or Dodge engines going into custom vehicles, buggies, sand rails, etc? Why has NASCAR decided to use the LS architecture as the standard in some of their classes and not any of the others?
Like I keep saying, there is a place for BBC's still. But in terms of efficiency, they pale in comparison to LS. And I don't just refer to fuel economy as efficiency. Efficiency is also power per pound of engine and power per cubic inch, both of which LS DESTROYS BBC and SBC. I think the main question is power per dollar spent, which is what I think is debatable.
J. J.
PS: You're not pissing me off. I am trying not to do so to you also. I'd run a BBC in a vehicle where I wanted lots of power, didn't care about weight, and didn't have a lot of money to spend.
