Pile-o-parts help
fl-krawler
Do you ever get to a point where you are sitting on a pile of parts, and/or a few partially completed rigs and you can't make up your mind what you want to do. I was building a 4 seat rockwelled buggy on 47's, until I decided I wanted to build something much lower to the ground on 14b/rockwell hybrids with a lot more power (compound boosted L92). That build is still going to take place no matter what. My dilemma lies with what to do with the Jeep TJ I have, as well as the old chassis I lost motivation to finish. I have been wheeling a borrowed TJ juggy on rockwells for almost 3 years now, so I am ready to be in my own trail rig (not to mention, in April the owner of it is moving to Tulsa, so I will lose access to it). All of my wheeling buddies are pretty much finished with their builds, so I am starting to feel some pressure from them (and my wife oddly) to get something wheelable soon (which isn't easy between building stuff for other people, and going to school full-time).
Here is what I got:
97 Jeep TJ. All stock and uncut. No axles or suspension under it currently. It has a built LS1/700R4/D300 in it, and a full cage. Jeep needs the frame replaced (I have a new one), tube work to tie the cage into the frame, and all the suspension/motor mounts built on the new frame. I have a set of 1 tons, and coilovers, but I will need to buy gears, lockers, driveshafts, and steering. I will also need to backhalf the new frame, and build an under tub fuel cell for it.
Rockwelled buggy. Chassis is finished. Suspension, engine/trans mounts, steering, seat mounts, winch mounts driveshafts, exhaust, etc are finished. I would need to do all the tin work (floor, firewall, exterior skins, fuel cell), plumb and wire it, borrow the engine/trans/tcase from the jeep, and build an engine cage.
I had originally planned to build a new buggy, and take all the parts from the old one that was almost finished, and build a rockwelled 4 door TJ like Bret Burton's 2006 TTC winning jeep. That would have left me only needing to find a home for the chassis. Since then, I got the idea to build the TJ up on 1 tons since I thought I could finish it faster and get it wheelable sooner. Now I am stuck at a crossroads on what to do, and time is sort of running out (There is a wheeling trip coming up in 6 weeks).
So what would you guys do? Keep working on the TJ and finish it with the 1 tons and coilovers, then rebuild it into a 4 door at a later date OR put it on the backburner for the time being, and finish the buggy that is already 85% done and wheel it while you build a new, more badass buggy? It will be cutting it very close on the TJ just getting it finished in time for the next ride. I am about 90% sure I could have the buggy done by that ride.
5BrothersFabrication said:
I'd go with the one that you won't have to redo, like if you're expecting to be a dad (4 seater), or plan on running SRRS (bouncer).
No more kids for me, and I'm not really into the whole rock bouncing scene.
Build both. Get you one of those high limit, high interest credit cards and live like your rich for a while. Lol.
Sent from my DROID RAZR HD using Tapatalk
laughing1 molaugh molaugh molaugh molaugh molaugh :flipgotcha:
