Project "Secret Squirrel"
The Captain, and I use my MANLY compressor and threw the rims in the middle hole of the tires.......:D :redneck: :haha:
snwbrdpunk16 said:
30 bucks will buy 3 MAN hookers. :clappy:
and a compresser, that with the mad skilz of two man hos and a truck strap can put 4 large tires on rims and air up in 30 minutes or less! ILOVE BIG TIRES...I kept two here just for myself.....:redneck:
What are they now end tables or are they the coffee table so you can sit and stare at them all day
I am working on the GF to let me take them to bed with us:kiss:
Ok I rotated the clutch lever assembly and finally mounted the winch.
I also came home yesterday to yet another box. So heck, I had to put on what was in the box. Ya it was just a starter but it was---another piece of the puzzel :D
Ok the time has finally come to make the thing fully rollable so I can do a few more rigs. So I removed the front housing and finaished cleaning it up and threw it back under the rig. One thing I wanted to so was go ahead and do the 5th stud modification to the steering arm/knuckle.
Here you can see the area thats best suited for the 5th stud.
There is casting flashing on the knuckle that has to be removed and make somewhat of a flat platform. The area also just below where the arm sits has a slight radius to it. So I like to remove that area (There is plenty of material down in the knucle so you won't compromize the strength of the knuckle).
So then you want to go ahead and set the knuckle bearing preload (15 inch pounds) so that you have the arm height set that way. So once that was done I started to make the tabs.
im exited to see this 5th stud thing. i will be copying you on my toy axle, and giving you full credit :cool: :cool:
