LightBnDr said:A piece of tubing that sleeves the inner diameter. Heat it up to the 500deg range with a torch then beat the sleeve tube all the way through then let it cool. Beat the sleeve back out.
I thought those cans have 1 or 2 bolts that squeeze the bump stop housing so you can adjust them? Surely that's not a solid piece of tubing you welded on there?
Do the clamp style warp to the point that the bumps dont go in? I almost considered just cutting a slot down the side to basically make it a clamp style. Then just add a ring and nut to put a bolt through.the_white_shadow said:Try welding a vertical line to the center of the can and see if that brings it out some. next time put a piece of 2" 1/4 wall DOM while your welding. It will help it retain its shape. Ive been there before except with the clamp style cans.
Beerj said:Do the clamp style warp to the point that the bumps dont go in? I almost considered just cutting a slot down the side to basically make it a clamp style. Then just add a ring and nut to put a bolt through.
Yeah. The schrader is actually housed in a threaded portion that extends out the top. Then a cover plate, washer and nut hold the bump up and in.TBItoy said:They do warp, but you can stick a screwdriver or prybar in them and pry them open a little.
I would make those clamp style like you described.
It looks like the top is capped? Where is the Schrader valve on your bump stops?
I assume you mean 1.25" as far as length, not diameter right?74_Chevota said:weld on a small piece of tube (1.25" or so) for pinch bolt. Cut a slit up the side of the can to relieve the pressure and then you can use the bolt to tighten the can like a regular bump stop.
