Steel braided brake line
crash2
-Oh no I picked a side-
Da gold bar
So I do have a question on the braided hose itself since I see a bunch of variables (got the ends figured out).
So for -3 an hose it shows for inner diameter .125 or .140 and outer .250 and .375
Any input would be appreciated.
Huh, I always assumed hose was spec'd by the AN ID number. Wouldn't -3 hose be 3/16" ID (.1875)? OD will differ by manufacturer and hose finish (coated or not). I received some new -3 brake hoses (coated from Allstar Performance and non-coated from Fragola) a couple days ago. I can measure the OD if you like. I am not going to cut a hose to measure the ID, though :)
I always though -3 designated at least what the ID was.
As you can tell there are options,lol.
http://www.summitracing.com/search/...3+4294949392+4294924175+4294924174+4294947421
Ok so I got it figured out. I didn't realize each manufacturer calls for a type of hose to be used. So since I will be using all Earl's fittings they called for Speed flex hose with basically narrowed it to one type of hose :awesomework:
Thanks for the input folks it just took a spark to get the right info.
I bought some -6 Aeroquip ptfe hose for my hydroboost lines and it is 5/16" ID and 3/8" OD (of the inner core, not the braid). So much for standards.
