S shrtscrplr Well-Known Member Joined Apr 7, 2009 Messages 110 Location wa Sep 23, 2012 #1 I have a 86 4runner that when i turn the steering wheel it will make a pop and click sound. Last edited: Sep 23, 2012
K karhart77 Well-Known Member Joined Jun 13, 2007 Messages 539 Location Lynnwood Sep 23, 2012 #2 Tilt column? Check for debris at the joint. I had a screw fall into mine causing the same symptoms.
S shrtscrplr Well-Known Member Joined Apr 7, 2009 Messages 110 Location wa Sep 23, 2012 #3 Yes tilt. What joint you talking bout?
crash2 -Oh no I picked a side- Joined Mar 26, 2001 Messages 39,839 Location Da gold bar Sep 23, 2012 #4 Only 2 things that can make contact in the column. One is the horn contact and the other the cancel cam for the turn signal switch. Pull the lower cover and look...
