Tech Article: How Fox DSC Compression Adjusters Work
Can these reservoir / adjusters be added to a conventional fox 2.0 coilover with a standard reservoir? Would the main piston and valve stacks need to be changed?
They can be added to Fox 2.0 R/R shocks.
If they are existing shocks the price gets higher than if you just bought new shocks because so much stuff has to change (entire reservoir, hose, new hose fittings).
The main valving definitely has to change, but I can help with that.
They are badass once you get the valveing correct Loved my 2.5. At first I couldn't tell a diff by turning them but after a few tuning sessions they are badass
