Ok, nevermind then. Just had some suggestions for wiring it if you did. I'm running two of them.FordFrk06 said:well, i didnt get a 4 runner ECU, if thats what you mean.
Looks to me like you'd want a normal on/on switch. That would make it appear to be "off" when the switch is down, and "on" (locked) when the switch is up. I would put the whole circuit on an ignition feed.FordFrk06 said:so reading that thing, does that mean that i HAVE to get a momentary switch? cause i just got a on/off LED toggle switch. will that not work?
so do you mean that i should get an on/off/on momentary switch? cause from what your saying, if i use a on/off switch, when its on, it will constantly be applying power to the locking mechanism, and wont be able to unlock it in the off position, it will just stop supplying power.CrustyJeep said:Looks to me like you'd want a normal on/on switch. That would make it appear to be "off" when the switch is down, and "on" (locked) when the switch is up. I would put the whole circuit on an ignition feed.
An on/off switch won't work because the locker works like a power window; it takes power to lock it AND to unlock it.
Fairly simple really.
The two status circuits appear to be frivolous over complication.
No, an on/on switch. It acts like a on/off (two positions), but both positions close a circuit. So, with it up, the lock circuit closes, and with it down, the unlock circuit closes. These are not momentary, BTW.FordFrk06 said:so do you mean that i should get an on/off/on momentary switch? cause from what your saying, if i use a on/off switch, when its on, it will constantly be applying power to the locking mechanism, and wont be able to unlock it in the off position, it will just stop supplying power.
This is electrical, not electronics :flipoff:FordFrk06 said:bear with me, i suck at electronics.
so i heard.I have recently been elected the local authority on gayness, so you'll have to take my word for it
ok, i get it now.The reason you don't need a momentary, is that the locker has switches internally that disable the actuator when it reaches its extremes; one for locked, one for unlocked. The diagram shows how to wire them. When the locker locks, the lock circuit is disabled, no matter what your lock/unlock switch on dash is doing.
Wrong. The actuator has internal "switches", more accurately position sensors, that tell the ECU when to stop. It's just some people have decided to use these for a purpose they were not intended with mixed success. It seems these same people are the ones who complain about the e-lockers getting jammed or not being reliable. Go fig. :haha:CrustyJeep said:The reason you don't need a momentary, is that the locker has switches internally that disable the actuator when it reaches its extremes; one for locked, one for unlocked. The diagram shows how to wire them. When the locker locks, the lock circuit is disabled, no matter what your lock/unlock switch on dash is doing.
You telling me the diagram is wrong?skrause said:Wrong. The actuator has internal "switches", more accurately position sensors, that tell the ECU when to stop. It's just some people have decided to use these for a purpose they were not intended with mixed success. It seems these same people are the ones who complain about the e-lockers getting jammed or not being reliable. Go fig. :haha:
I'm telling you people running Toy e-lockers without the factory controller ECU are wrong. :flipoff:CrustyJeep said:You telling me the diagram is wrong?
Maybe they are wiring neophytes who couldn't wire up a light bulb :flipoff:skrause said:I'm telling you people running Toy e-lockers without the factory controller ECU are wrong. :flipoff:
I have yet to try hooking one up to an oscilloscope, but I'm pretty sure they are a pulsed power supply to get the motor moving more reliably as well as a braking circuit to stop the motor from overrunning and jamming the mechanism up hard.CrustyJeep said:Maybe they are wiring neophytes who couldn't wire up a light bulb :flipoff:
no problemRobinhood said:thanks that is perfect
