I've got an 82 22R, with a couple stipped bolts. I did a search and read somewhere that toyota OEM gaskets are the "better" ones to buy? Also, what kind of torque and torque sequence do you put them through... I have a helicoil kit to fix the bolts, but i don't want to re-stip them when i'm reassembling... Also, are there any clearance or general issues i should watch for with running an OEM gasket with a header? I know the manifold surfaces are a little different, but the bolt holes are the same...
kris
kris
