Toyota motorhome ???
There are some dually toy rear axles out there. Seen some early 80's dually pickups. There was one parked in Lynden forever. Most of the ones i seen where 2wd, so I'm not sure if they used a 7.5" rear end and 5 bolt wheels or 8" with 6 bolt.
http://seattle.craigslist.org/sno/cto/1510605104.html
looks like 5lug
The first ones were just 7.5" axles with odd spacers. they had wheel bearing issues so they had a recall on them.
The later ones (WAY more common) are all full loaters with a large 6 lug. 8" diff just like a 2x V6 or 4x. You can replace the large 6 lug hubs with standard solid axle hubs but you have to either make a 5/8" spacer for the flange on the shaft or shorten and respline the shafts.
