bbone
I was just about to offer the same thing
CHASMAN9 said:Wanna borrow a set and see for yourself?
nealcj8 said:43's on Trailready's
snoball said:http://secure.trbeadlocks.com/17x8-125-45hd17beadlockwheel-2.aspx
New Hardrock Trailready are 10" wheels with only one back spacing available, just for the larger demand for big tires. This is what I just ordered for the new rig. I decided to try the
Trep 42s after being happy with 2 sets of SXs. Hope I don't regret it.
redneckengineered said:Nice WOD rig. What's the BS and overall width on that digger?
redneckengineered said:I've got a spare Trailready sitting on the floor of the shop I could mount a 43 on for test fitting. I'm pretty sure I'm going to have to drop from the 4.75" BS I have now to around 4" at least to clear my steering arm. It's really close to the sidewall of my Krawler now.
nealcj8 said:Thanks, but its a knock off I built it myself. I am not sure on the backspace or the overall width but I can measure when I get to the house.
CHASMAN9 said:I should have said it like this, would you like to borrow my set of 43's on Racelines and run them to see if you like them? I will be at AOP New Years with them if you want to give them a go? Let me know, G
slravenel said:are you totally against the option/possibility of needing to run a small spacer?
They haven't came down much then.zayne2427 said:Called today. Goforth is $690 each for the sx sticky
Waffle said:8.5" TR HD, 3.5" BS, 90"
I keep 4.5 in the rear and still experimenting on the front. 7 psi will hold up front, 5 psi won't. The drivers front in this pic was my first time trying 5 psi and it was going down with working slow goin hard side loads in Lions Den at Harlan.
redneckengineered said:Looks good. What is the opinion on the wheel width with these tires. Trail Ready has the 8.5 and now a 10". Most running Racelines are 9.5". Any noticable difference?
