Flatlands #1
AllGoNoShow said:
Don't take this wrong, I appreciate the work that went into that hood, the fab is top notch. But I don't think it fits the build. Just my humble opinion.
Hold your judgement for a day or two while I finish it out, it's still pretty far from what it should look like...still to early to know if I'm gonna be able to make it do what I want.
Forbanger said:
I like it
I think the rivets would look good as a method to attach the scoop, plus would be easier to replace if it ever gets wadded up.
valley in center of the hood taking shape....more trimming on the front to fit the tube still but its getting there!
moved the chassis to the paint room and Dillion finished up the roof
Looking great! I can appreciate all the hand made effort in this unit.
Enjoy learning tig, it'll change the way you look at all forms of welding.
Keep hammering on the aluminum, tighter the joints the better... just need a bead roller now to spice things up????.
Matt Cutler
Sent from my SM-G892A using Tapatalk
Matt Cutler
Thanks man, it's been a learning experience for sure.
A bead roller is on the list for sure. I scored a couple decent sized arbor presses the other week, going to pick up a set of shrinker/stretcher jaws for future sheet metal work as well. thumb.gif
AllGoNoShow said:
The roof looks great.
appreciate it :dblthumb:
Steelit...
My pics won't really do justice to the color or finish, I'm sure Ray will post a few next time he stops by.
Prepped the chassis with wire wheels and scratchpads, no one wants to see pics of cleaning tube..so we will just get into it.
It's been a bit chilly lately so a slight preheat in the sun for good measure...
Spraying it out of a cheapo harbor freight gun. It's worked well enough, it's a bit thick for the standard filters.
I'm sure they make a different filter that would work...I found taking it out works just as well though.
Stuck a couple bolts in the lower link mounts to hold it up while I put the final coats on it.
Beerj said:
Were you able to get everything painted with one gallon? Looks great!
Thanks.
Yes and no, I ended up spraying just over 5 quarts,It ended up around 4-5 coats on the chassis and a few other pieces with 2-3 coats. If you only did 2-3 coats on the chassis I'm sure you could get it done with a gallon, I'd buy an extra quart just in case it needs another coat or you miss a spot....not saying anything like that happened..but I only planned on putting 3 coats on it ::)
Random picture dump
1/2 ton conversion
Forgot where I saw this..may have been jducks thread, no room to fit the standard heater loop hose.
Ray went and bought way to nice of rims..
Kmc machetes
These things have a serious grip on the rear of bead lock ring.
In the interest of fire safety we are covering the fuel and tranny lines with Aeroquip Fire Sleeves.
Guys.....just say no.....to split loom.
Took the better part of the day to get this stripped so I could start chopping out 6feet of wire we don't need.
It'll be getting the bulkhead pass through and techflex treatment, doubt there is many pictures...I don't think anyone wants to see me soldering and heat shrinking junk.
Got new skips for the build today...Thxs Goforth!!... also picking up the tranny Friday so its getting closer :driving:
Back ground looking good without all them down tree's. The pond looks different as well. Is the fence holding up?
Oh yeah this is a buggy thread.. Its awesome as well.
Lol.....that background looks good cause you guys did nothing less than kick ass on cutting up trees and making this place look like white people live here sgsin . No **** ....what u guys did in a weekend I would still be working on....you guys are awesome!! BTW ...**** hurricane Michael
I agree on Michael. I sure wish I could make another trip to help folks out. I can't wait to see the buggy in person.
Another random set of pics, I'm all over the place at this point.
The fullish droop pics from putting the shocks in.
FedEx dropped the ball on these...or something heavy at least.
Using wods flexline brake kit with stainless hard line filling in the gaps, also running the trickflow steamport kit.
Wilwood residual valves
Ajk clamps all around
And that brings us to tonight.....more wiring. Bulk of the engine harness is routed and ready to be pulled for final trim, techflex and cannon plugs.
