1943 MB Tube thingy updates...
heep70 said:
Spend some more money on it, so we can see more updates. :corn: :cheer: :D
Well if you want to see more you can send all the paypal donations to my e-mail - I swear all goes to the jeep :flipoff: :flipoff: :flipoff:
But seriously I am aware that it is going really slowly but I am make some progess...
I will get some motor pics up tomorrow... :rolleyes:
Harvester of Sorrow said:
Someday this thing will get finished....right Matt?
I have been e-stalking you and this build up ever since you built your rims up...and started the tube work...and cut the body...and....
How long ago was that now...? 2-3 years ago:clappy:
You don't know the half of it - I thought Lacky was bad when he had 7+ years into the 4-runner... I bought this thing in 1998... :wtf:
LPG Stroker Motor Pics
Only 3 days lag :looser:
This is what I have going under the hood - jeep six .040 over with 258 crank and rods - .060 off the top of the block to bring the quench back...
Everything has been balanced within 0.1 grams...
The gilmer (cog) belt drives off a hub that picks up the extra .420" of crank snout from the 258 crank and also uses 3 5/16" countersunk allen screws in the puller holes of the damper... Then I used a longer AN -8 bolt for the damper bolt to hold it all together
SInce I am using an external hydraulic pump I did not want the OEM p/s pump - so what you see is a factory part - just impossible to find; the tensioner blocks came on YJ's with manual steering (lots of those running around; huh!) :rolleyes:
And if you cant tell I got a bit carried away with the electroless nickel plating
Enjoy
Matt
heep70 said:
WOW, lots of moneys there. That should be some big horses for your ride.
Start with two free blocks (thanks Robin), some trips to the pull-apart yard, LPG stuff off ebay, and a good eye for scrounging
Way less than you think - the rebuild kit was ~ $375 - another $350 in machine work (since I did not feel like trying to do it here at the shop), ~ $100 in lpg stuff and ~$150 in misc plating and other expenses... All in pretty cheap for "doing it right"
I am the king turd polisher - you should see my D30 :stirpot:
I am waiting to the heeps of sh1t about the plated motor mounts!
crash said:
Wow--- lookin good matt
And if you pull a lackey I will beat you down :D
It's good to feel the love :flipoff:
If I ever had a problem it is not selling things - I still have crap I don't even run; like 4+ p/s boxes for the cherokee...
Anyone want some saginaw boxes - free to a good home!
Are they the same at whats in a zj?
Should be the ones - how many do you want - most have been drilled and tapped for hydro assist - and a few are missing caps but all ran and did not puke oil at one point...
Oh reallllly.. I was going to drill and tap it so I could swap it out on kelly's rig :redneck:
So what should the engine put out torque wise..I was thrown for a loop when i saw yer putin a 6 in there, I figured a v-8 for sure...Going for "low" weight or what was the plan there? Man, I seriously dont care if you ever get it done, Just keep posting unique eye candy...Looks great.
Edit: the nic plating is bitchen..if ya got any stainless i can electro polish it 4 ya.
I know the motor and had two blocks so I said what the hell... I also like the idea that most spares cross over from my XJ to this
I don't know a torque number but I figure low 200's on HP and probably similar ftlbs - but we'll see...
Plus I wanted to be different...
Matt
I should have some more homebrew doubler box stuff in a little while - NP242 went under the axe....:corn:
War-Jeeper said:
That thing is sick! I see some of it that even resembles my rig!!! What did you start out with originally?
I had done a bunch of work to what is in these pics but all the other pics are hard copy - I will try and find the original photos when I bought it...
This was when the project went from the bland 1 ton running gear and 38's planned to full tilt rockwell/53's/4 wheel steer...
Matt
