5BrothersFabrication
Zzzzz....
So the other day, sitting in a drive-through and start smelling coolant. Come home and I'm dripping coolant from what appears to be the water pump. Check the radiator, only a 1/4 gallon low, but when I filled it up, there was oil spots in the coolant. Check the oil, no coolant. Figured it was something to do with the timing cover/water pump, so I bought a pump. As I'm taking the pump off, I'm pulling a bolt and coolant is pouring out the hole. Get the pump all the way off, still dribbling from the hole. What gives? This happen to anyone else?
