TreeClimber
What is your wheel bolt pattern?
8 lug one ton stuff, not sure the spread on 8 lug
Just a FYI, loosing an inner bead has more to do with tire pressure than beadlocks preference. I have lost an inner bead on my TR's a few times but only when I allowed the tire pressure to get too low. Also take into consideration that stiffer sidewall tires are more prone to a inner bead loss when pressure gets too low, as where a more flexible sidewall holds a inner bead better at the same low pressure.Love my Aluminum TR's. No problems losing an inner bead like my buddies allieds. On a snow run a few weeks ago we spent more time F'n around with his tires then wheeling.
I don't think you can loose a bead with a staun. Same with stazworks... I wheel with a guy who runs stazworks and he just pulls his valve stems... it also a fairly light rig on 54s
We run 0.5psi on 36 bias iroks, no locks lol..
2. 5 to 8 if not snow
Anybody ever lose a bead with stauns? 54's are one thing but what about the usual 35 to 42's?
What's the weight of the rig? I got a 4runner w/sbc chevy coming on line that will have 35-37's and like the idea of stauns but would like to know if there any draw backs?
I run stauns and I like them for the most part.. a few issues:
* Doesn't stop debris from getting into the outer bead, causing leaks (and having to dig them out)
* a PAIN IN THE ASS to remove and almost impossible to install. Find a specialty shop who can do it. it cost about $200 to mount 4 tires.
* Airing down can be an issue if you don't install them right. The airdam can get dislodged, basically sealing off your valvestem
If given the chance to do them again, I probably would.. they're nice for the road.
