al1tonyota
Ar you going to support the radiator in any other way? If not I think it is going to tear the tank material just my thoughts...
Flex if you roll or weight from bottoming chassis out like front off the ground and belly slamming down. Your welded on pieces are pretty far from the outer edge so it will have more area to try and flex the sides of the tank material.pholmann said:Think so? Due to flex or weight or both?
