Chattanooga Whiskey Buggy Refresh
wizzo
glasgow, ky
Andrew (redneckengineered) and I had been talking about him either having a new chassis built and me swapping parts or doing a full tear down and refresh on his current buggy. He was happy with just about everything on his current and the OG Revolution WOD chassis. So the decision was made to go through with the full tear down and refresh. Andrew had a good list of specific points he wanted addressed or updated. This buggy was built in 2011, lots has changed since then and some parts were already updated along the way. But the hope was to bring things up to speed with the current technology.
Andrew had already ordered some new seats and stripped the panels off to do a good pressure washing before I tore into it.
First thing to do was add some rub rails and fix some damage tubes.
Transmission cooling was one thing Andrew wanted to update. You can see above the smaller griffin fluid cooler he had been using. While it worked ok, it left something to be desired. I have been running a large CBR fluid cooler on my buggy for a few years. We decided that was the way to go. It's a tight fit but it's in there.
Upgraded radiator was also a must. Andrew hadn't had any major heat issues but it was something he didn't want to have any concern about anymore. Again CBR got the nod. Quality is second to none.
I built a "sandwich" style mount for the radiator. That way any chassis movement does not get transferred to the radiator.
Added a rear "bumper" for them late night trail racing! It's .250 wall if anyone thinks they want to test it! LOL
Fresh skins
wizzo
glasgow, ky
More aluminum
New shifter and console with cup holders.
Straitened and reinforced the lower bars on the chassis
All link tabs and shock tabs got weld washers. Lower link tabs got reinforcement!
Obviously there was a ton of other work but that was basically the high points before the chassis got sent to Nashville to be re powder coated
wizzo
glasgow, ky
Something in particular Andrew wanted to upgrade was the gauges. He had done a bunch of research and decided on the AEM CD-7 set up.
Andrew worked with both MAST motorsports and AEM to get the MAST ECM and AEM CD-7 to work together. This is the basic display you get. Andrew has a custom lay out and back ground he can share.
wizzo
glasgow, ky
Both front and rear axles got some love. Front axle was pretty fresh build so I pulled the cover, inspected, resealed everything and painted the housing. The braided brake lines had to go. Steering ram got rebuilt, lightened things up quite a bit with new Mark Williams brake kit and tied the steering arms into the knuckle.
wizzo
glasgow, ky
The rear was torn down completely and the third member was sent off to be freshened up. Axle got fresh paint and new Mark Williams brake kit.
wizzo
glasgow, ky
We couldn't just go back with the 2.0 radflo's he had before. Andrew pulled the trigger to step up to some 2.5's! I also shortened the stroke on his bump stops and rebuilt them.
Transmission was sent back to PTC to be freshened up and added an ultra bell
Fresh Sanderson headers with v bands welded on from WOD
I wrapped with DEI titanium heat wrap
New exhaust through out and muffler. All wrapped.
wizzo
glasgow, ky
Wiring and plumbing is something I enjoy. I thinned out his engine harness and replaced the plastic loom with mesh. All accessory wiring was replaced. New switches, fuse panels and relays. All new hoses everywhere.
Got rid of this large factory connector
Ditched the white connectors the SPAL fans come with for some weatherpak
wizzo
glasgow, ky
All new hydraulic lines made in house and replaced a few brake lines
New fuel line with heat wrap and secured to the fire wall
wizzo
glasgow, ky
Random details
Used the existing panels but cut this one out and added wire mesh to allow some air flow around the trans cooler
Something I like to do is make sure the link tabs and shock tabs are contacting the shank of the bolts. I buy longer bolts and trim to fit. This gives you the most strength in what I feel like is critical points.
New hardware
Old hardware
wizzo
glasgow, ky
Chattanooga Whiskey Buggy 2019 Refresh Walk Around
I truly appreciate the chance to rebuild this buggy for one of my best friends. It was a very nice buggy to start with and hopefully Andrew will enjoy it for many years to come.
Any questions yall have about things I did etc, I'll be glad to answer. I hope to be able to keep adding tech to Hardline.
The-Boss
This has always been very important to me and is something I do for everything I build. Their is significantly more strength at the shank than the diameter at the root of the threads. Also the threads like to flatten out or dig into the tab causing it to get loose over time and compound stress.
Buggy looks new and I'm sure will work better than ever.
