COLEWORX
COLWORX PERIOD
FORSALE!!!! JEEP TJ COLEWORX RIDDLER
Not interested in any trades, Price is 65,000 This Feb the jeep will be 3 yrs old. Motor is less than a yr old and trans is 6 months old! truck needs no work, has been well maintained and is ready to wheel!
CONTACT Charlie Fox @ (931)619-0650 THANKS!
new (931) 619-2218 or text
Specs. For ColeworX Riddler
Frame/Chassis Design ColeworX Design
Frame/Chassis Materials 1 7/8-inch DOM
Overall Wheelbase 115 inches
Overall Length 158 inches
Overall Height 72 inches
DRIVETRAIN
Front Suspension/Type/Materials 4-Link with 1.25-inch heims
2-inch HEX
Front Sway Bar Currie Anti-Rock
Front Shocks 2.0 Fox w/ remote reservoir coilovers
Front Bump Stops Fox 2.0
Front Axle Housing 14 bolt w 300m axles Solid Cs Deanbear Knuckles
Front Differential/Locker Detroit
Front Ring and Pinion/Ratio 4.10
Front Differential Cover ColeworX
Front Axle Shafts RCV Performance hardened 300-M
Front U-Joints RCV Bell
Front Drive Flanges Polyperformance Chromoly
Front Brakes Wilwood Dynalite
Front Steering Setup KRC full hydro with Eagle Machine
Hexagonal single-ended ram
Front Drive Shaft High Angle Driveline, 1410 joints
Rear Suspension/Type/Materials 4-link with 1.25-inch heims
2-inch HEX
Rear Sway Bar Currie Anti-Rock
Rear Shocks 2.0 Fox with remote reservoir coilovers
Rear Bump Stops Fox 2.0
Rear Axle Housing Corporate 14 full floater
Rear Differential/Locker Full spool
Rear Ring and Pinion/Ratio 4.10
Rear Differential Cover ColeworX
Rear Axle Shafts Dutchman 300-M axle
Rear Brakes Wilwood Dynalite
Tire Make/Size 43x14x17 TSL SX STICKY
Wheel Make/Size 17x9 Aluminum Raceline with custom
ColeworX polished rock rings
POWERTRAIN
Engine Make Chevy smallblock 383 Eagle rotating assembly Dart Pro 1 heads, Big Stuff 3 Fuel injection
Batteries Optima
Radiator/Fans Be Cool twin fan setup
Air Intake K&N
Exhaust Custom 3 ½ -inch chrome plated
Transmission Make PTC TH 400 with reverse manual valve body
Nitrous converter with 2200 stall and Durrelle
Durele Trans. Cooler
Transmission Shifter TCI custom gated, no cable
Transfer Case Atlas 4.3 with custom HD 300-M output shaft
Fuel Containment Custom fuel cell with in-tank pump air motive 1000
BODY/INTERIOR
Body/Body Panels 99Jeep TJ
Body Modifications Narrowed 6" and chopped 3"
Skid Plate/Material 1/2" 6061 aluminum
Hood/Grill Jeep TJ grill cut down and Cambpell enterprise Hood
Floors/Firewalls Custom
Dash/Gauges/Switches Carbon Fiber Autometer
Steering Column/Wheel Grant
Pedal Assembly/Cutting Brakes Wilwood dual pedal assembly
Seats/Harnesses Corbeau GT 40 with Simpson Racing Harnessess
Winch Front Warn 9.0 RC
Pics http://www.rickybphotography.com/Rig-Features/ColeWorxRiddler/10980742_SpC663#!i=767589716&k=WqmW5kC
Pics http://www.rickybphotography.com/Wheelin-Galleries/ColeWorxTNride/10987992_sCwqGd#!i=768150910&k=DFKxKKj
The Nasty Riddler
Making of The Riddler
DRIVETRAIN
2-inch HEX
2-inch HEX
POWERTRAIN
Batteries Optima
Air Intake K&N
BODY/INTERIOR
The Nasty Riddler
