What you need to get the proper steering throw out of the axle is the measurement off of the factory axle. You want the distance from the ball joint center line to the draglink hole on the factory knuckle to be the same as the distance on your 44 high steer arm.
Then if you want it to steer more or less than stock you can adjust the distance bring the drag link in toward the ball joints for more steering/ more force required to steer or out for less steering/ less force required. That is if the axle/ joints will support more steering.
