Elliott said:I would put Rockwell knuckles on it and go 40 spline all the way. There is no sense in going to an 80 and running anything smaller than 40 spline stuff, You would end up with a strong ass gear, and axles that would be your fuse, only real sense in building an 80 is to be somewhat bullet proof.Best case scenario is 2" all the way, second best is 2" stubs and 40 spline inners, third is just straight up 40 spline, any one of these options would be plenty strong enough for 95% of us.
BHUDSON said:Thanks for the feedback. Sounds like 40 spline is the way to go for my purposes. Are the crane c's & knuckles the best? I was thinking about these C's
http://www.polyperformance.com/shop/Solid-Axle-Industries-D60-Kingpin-Inner-Knuckle-C-Ends-p-2689.html
BHUDSON said:Awesome. I'd like to hear more about that f450 set up
fl-krawler said:https://www.facebook.com/media/set/?set=a.553952041341258.1073741832.188262791243520&type=1 I was quoted at $2600 for all the parts to do one axle, which I thought was pretty steep. I can do rockwell steering with Ouverson super-8 hubs for about a grand less. Rock solid said their assembly weighs 97lbs per corner.. The rockwell parts are 110, so I can't see spending the extra grand to save 13lbs per corner
TBItoy said:If I were building an 80 center, I'd defininetly go with some badass fabricated knuckles that could accept Rockwell parts.
Otherwised I'd just build a HP60 for a lot less $ and use off-the-shelf parts.
TBItoy said:does the rocksolid setup include brakes?
fl-krawler said:No brakes. Just inner c's, knuckles, ball joints, unit bearings and drive flanges. Rocksolid said that Dale Larsen was running that knuckle setup. I tried running the D60 sized RCV's and had issues stripping the splines out of the CV bell. I don't like breaking so that puts me in rockwell sized u-joint territory for reliability with 47" tires and lots of HP
