Ftoy #518 build
Re: Re: Ftoy #518 build
Not much of an update
But I'm almost ready to fire this thing off.
I ended up purchasing a new harness from psi along with a new ecm.
The wiring harness semi to be top noch
I will be finishing up the front links this weekend along with the fuel system
I like the big upper link in 3 link setups and have saw it used tons with no complaints,,,probly what will go under the front of mine one day bla bla bla.....
Haven't updated in a while so here's some pics.
This was the ND result of the motor rebuild
Im not 100% on the exhaust decission. Ended up with sandersons headers 1 5/8 primaries and 2.25" exhaust. Since my chassis is tight with links and drive shaft being inches from each other I ended up with this design
wonder if I'd be choking it with one exit
Whoa...I haven't been in this thread for quite some time and I come back to find an LS motor and one tons....and you hanging from a tower a couple hundred feet off the ground.
Progress looks good, but do you have a shot from the side of the front suspension?
I didn't like the short front links but they came with the axles setup so I ran went with them to save a Lil $
Oh and this would be my first link suspension experience ... trial and error
Got things iv ordered trickling in..
Twin sticks
Winters shifter
Solid drive flanges and diff cover
Throttle cable
1350 yoke for front output of the 205
Finally got a real fire wall in the buggy for the first time. so far im liking it just due to I have pl
aces to mount things.
Damn tap talk isn't allowing photos to load I'll try back later..
