My Angryfab buggy "ISSUES"
Re: Re: Re: My Angryfab buggy "ISSUES"
Eddyj said:
You don't want me working on this.... it's way too nice
The pictures make it look better, that's why I didn't get to close
zukimaster said:
Black buggy's matter to! Looks awesome man
Sent from my Moto Z (2) using Tapatalk
Haha, thanks. Trying to get coolant bleed now so I can take it for a spin
Unfortunately it has a little lifter tick. I know ls engines have that as a common problem. I should have changed them when I did cam, but I was being a tight wad. I have read trying marvel mystery oil or sea foam can help. If not it will probably be ticking for a while, till I have time and want to, to pull the heads
Looks and sounds great. That lifter might free up after you run it a bit. Or you could pull the valve cover and put a little atf down the pushrod hole. Or just let it tick. Did you get to tear around in it yet?
I read about the atf, may give that a try also
I drove down the road a little ways. Haven't bleed the brakes, because haven't had anyone to help me. Didn't want to get to crazy and crash.
Lol yeah, that wouldn't be too fun. Fwiw, those little vacuum bleeders are pretty cheap and in my experience, work better than the old pedal pumping method. Plus, it's a 1 man job.
I bought one from harbor freight, but couldn't get a good seal, I may see if someone around here has a better one
Well, I'm an idiot. I guess I forgot to tighten down a rocker :****: but on the upside, u don't have to pull the heads now
Looks really good. When you are strapped in can you reach the transfer case shifters? Maybe its just the picture...they seem far away.
Thanks Yea, I can reach them
