86tuning
I'm in the 'parts gathering' stage of my OBA system on my 84 Toy pickup.
already got:
- stock (denso?) 22R a/c compressor
- stock compressor bracket w/ tensioner pulley
still to get:
- pressure switch, moisture trap, fittings
- hoses, hard piping
- tank, brackets, safety valve
Plans:
- OBA, w/ pressure switch at 90-120psi or thereabouts
- air fitting inside bed of pickup
- small air tank tucked out of harms way
- functional spare tire carrier
I understand the vane-type compressor lubrication requirements, and want to run a small-ish air tank ahead of the left-rear tire up in the bedside.
What does everyone run for plumbing? I'd like to use metallic piping for best condensation extraction, and avoid nylon hose, although it meets the pressure specs.
How about 3/8" or 1/2" aluminum piping, commonly used for fuel plumbing? 250psi rating.
http://www.russellperformance.com/mc/fuel/adapters.shtml
http://www.russellperformance.com/mc/fuel/lines.shtml
What might be some easy to install and more economical alternatives? Steel brake/fuel piping would work, but could corrode...but the oil-mist from the compressor should slow that down a lot.
TIA.
already got:
still to get:
Plans:
TIA.
