skyhigh
Im looking into an onboard air system and was wondering what your running and wich system works the best.
The YORK compressor is the older style factory AC pump widely used thru the 60s/70s/early 80s. It's still reasonably available at any wrecking yard (or can be bought new still) and is a piston style compressor with an oil bath crank style. Works great when mounted upright. Works well when mounted lay'd down - but will require an oil seperator if the high pressure (output) is on top of the low pressure (input) fitting. [I think I got that correct, but might be 180* off]
This style system can be bought NEW from Kilby Enterprises, and in my lowly opinion is the absolutely BEST system sold today. You should do a little searching on KILBY's website, and you'll learn quite a bit.
I've ran Kilby style settups on my CJ, YJ, and now my TJ with great results.
The smaller Viaair systems, don't produce near the volume of air, require lots of electrical amps, and seem to not hold up all that well.
The smaller ARB pumps suffer an even worse fate
The airtanks need refilled ($$) and are an extra item to carry.
my 2 cents
i almost bought a viair so good thing you warned me ahead of time
So a rig rolls 100 yards down a hill and looses 3 beads.just putting that out there to think about
