Wildman1
So about a month ago I took my son up to Little Naches for a day of 4wheeling. It was his first ever REAL 4wheeling trip and his first trip out in his new Scout that he had bought. Of course everyone thought I would end up towing him back into camp. Well of course things don't normally end up as planned.
We went up to Ravens Roost or attempted too. We went on the upper part of the Powerline trail. We spent most of the day clearing downed trees as we were the first to go thru for the year. I ran out of fuel in my chainsaw so we turned around and headed back down the trail. Well we came to a large mud hole that I had seen guys play in a few years (10) ago. Being the big tough Jeep guy I figured no problem I'd make it thru no problem.
Those are 38" tires gone into the mud.
We stopped once we got to the road again to air his tires up and mine. The Jeep ran fine all this time and continued to run until I got to the T at Hwy 410. Just as I pulled onto Hwy 410 I lost all power and the Jeep died. So I towed the Jeep home and have been messing with it ever since. So far I have pulled the fuel tank to see if the pump was clogged, cleaned the pickup and tested the fuel pump. Reinstalled the fuel tank but still no start. I also have 40+ PSI to the engine fuel rail.
Of course my OBD II scanner stopped working at the same time as all this. So next I have clean as much of the under carriage as I can to try and see if there is a problem there. I can't find anything. I have replaced the crank position sensor and also have tested the throttle position sensor and still no fix. Right before I left for the PNW4WDA Trail Jamboree I tried to dump a little fuel down the throttle body and still no start. So during the week I was up camping with NO JEEP to drive I pondered that it might be a spark issue??
So got home and checked the spark, It's got some!! Just to make sure my ignition system was ok I did a tune up on it. Replaced the dist cap, rotor, & spark plugs. Also did a compression test while I had the plugs out.
So the Jeep will start and run at an idle but not all that well. It will die the minute you try to give it any gas. Once you have started it and it dies it will then not start again.
So throw some ideas out there guys--(Please other than get rid of the Jeep)
