Project "Secret Squirrel"
moto261 said:
Nice work what springs are you going to use up front ?
:cheer:
Jeep Wrangler 4 Leaf Front Spring 1987-1995 Part #52003448 :D
THis thing is a true HYBRID!
OK after many woes I have tires in my posetion...I originally wanted the SXs hower after waiting for the last two months (nearly) I got TSLs, its my bad I figure I couldn't comunicate or the guy didn't hear the words coming out of my mouth...and they now want 40 more per tire....I will Wheel the hell out of these and then get some SXs next.:cheer:
OH and the Turtle shows his little face on the door step today...too.:cheer:
SO here is how the stinger ended up. The supports just miss the lower edge of the nose and dive on to the top of the frame. Should also give me a good base for any tubing I wanna do from the rear to the front.....
I also built new body mounts so the nose is now hard maounted.
Now of course---I couldn't let that rust free metal just sit there--had to throw some paint on it. Whats funny is the front diff has been stripped and sitting bare before I even cut anything off the rig and---its rust free. Something about the steel on this damn rig....
But in any case---here are some purdy pics for ya jack :;
SInce I had the nose off I went and took the plasma to it and removed some of the inner fender wells. Went far enough to where I could now easily remove more with the nose on the rig if need be....
And here is something that will TOTALY get you wound up jack and make ya wet
Look its now sitting under its own weight :clappy:
I have to rip the winch apart and rotate where the release lever sits and then that will be ready to drop back in.....
:clappy: :clappy:
yOu CAN SEE how soft those springs are......Too soft?
tires getting mounted tomorrow, we'll see must of a fight they put up:D
Jeepless said:
:clappy: :clappy:
Heck no--there is too much arch to the right now. But there is no winch/hood yet--no shackles and the weight is shifted to the rear still so it will probably drop 2" from there it sits now by the time I am done....
Good point, HOPE they don't go flat:flipoff: :redneck:
