Mudmixer
Member
Ok, wanting to go with the trail gear greasable shackle kit, right now I have stock rear setup up front under the frame. I want to go in the frame which kit should I use?
Ok what I am needing to know is what is the difference between offset front shackles and the stock rear shackles I am running now. Which kit would be best to mount inside the frame instead of underneath.
You will have to the the shackle tube kit- that is the tubes that will go thru the frame. Then you will have to buy a front shackle kit. When you decide you are ready to do it, I have it all sitting on the shelf if interested.
