tonybolton
Bypass Crawler
So after yesterdays heat wave ride, I have some questions and concerns.
Stats:
1998 5.7 Vortec motor
mid 80's TF727 auto trans rebuilt 3 months ago with a reverse manual valve body....very firm shifts, new / stock torque converter. (odd combo I know, it uses some big adapter plate)
1 ton axles
43's
4.88's with 4.3 atlas
YJ Juggy
I only recently installed a trans temp gauge and have been on about 4 rides with it. Temp gauge seemed to stay around 200-210 most of the time. This was with a random 11x8 "zip tied to the radiator" trans cooler. Engine temps stay in the 190-210 range. This was when the weather was in the 70's-80's. I'm also using a Taurus fan for engine cooling.
Wanting to lower temps a lil more, I opted for a stand alone trans cooler with a fan. It's about 10x8 with an 8" fan on It, and I mounted it just forward of the fire wall on some of the tubing with the fan visible from outside blowing into the cooler towards the engine. Hood has LOTS of holes cut in it for ventilation. Plenty of air behind the cooler and plenty after(blows sorta at the brake booster)
I did a lot of trail riding yesterday on the first outing with the new cooler and wasn't happy. A lot of these trails were on long drawn out hill climbs but I want to say I was in 2wheel low, using 2nd and 3rd gear 90% of the time, RPM's in the 1500-2500 range. Granted, it was most likely 100+ degrees or more but my trans temp gauge would just peg at 250 and sit there(engine temps stayed at 210-215ish). No change at all in the trans shifts and the fluid is still nice and red.
We'd get to shady / rest spot and I would let the rig idle with the hood up for about 5 minutes and the trans temp would go down to 210-220. The fan on the trans cooler is wired up as key-on for now, no thermo-switch.
I obviously know that trans temps over 200 are kinda nice to avoid, but I'm wondering if I'm getting an accurate reading of the actual temperature? I have the sensor located in the rear most actuator? servo? ....whatever that things called, test port. It had a 1/8 npt plug in it. I searched the 727 trans a bit for this location and found that this was where Dodge installed their factor temp sensors from the factory.
My next step is to install the sensor just AFTER the cooler to see if that reads any different. Anyone have any feedback or advice on something like this?
Stats:
1 ton axles
43's
YJ Juggy
