I just use wheel bearing grease.
Yup most of the time that's what we'd use. next time I have my buddies bender over here it's getting a lube holder welded to the stand. It gets old having to bend over to grab the tub of grease only to knock your head on the fawking tube you're bending on the way back up. :haha:
I lube mine haha before I slip it into the haha tool.
Well duh smearing in on the outside doesn't do a damned bit of good. :redneck:
But ya gotta have a place to put the lube when not in use and on top of the die is not a good place as we've found.
Maybe a bench :fawkdancesmiley:
Damned bender is pneumatic and on on casters so it's always moving around. It's easy to weld a piece of 4" scrap exhaust pipe to the stand and be done with it. :flipoff:
My benches are covered in crap... :haha: I gotta get out there and finish finding them again damnit. :booo:
There is your problem--organizational skillz...
I have found the spray stuff is messier than anything because it leaves crap all over (be it missed shot or drips). You can get a large tub of grease real cheap at napa (I have a separate tub for tube). Regardless of what you use you will have to remove it so not one type of covering is going to be easier than the other to remove.
I tend to hold the tube in a verticle position when I spray the bend area. Then it runs down the tube not off the tube.
Thats some crazy rationalizing there bud. There is no way its easier to clean grease off a tube than simply wiping oil off with a dirty ol rag. I can wipe oil with the same rag for years. Grease will eat/ruin a rag in one or two wipes.
Do you purposely do things the slowest and hardest way you can think of?
Its like saying drying off your hands (=thin oil) is just as messy as wiping your ass (= thick grease).
right on Crash....the spray works great...you are a bad aim :haha:
I am actually
Do you use the lithium type of spray grease bill?
