Where to find shims/spacers for XP900 radius bars with heim joints???
JMR7810
Building rear High Clearance raidus bars for rear of RZR XP900,
Gonna use hiem joints for adjustability..
Needing to find someplace to buy shims/spacers to tighten up heims in the factory mounting points..
PLEASE ANY HELP WOULD BE GREAT.. I'm having no luck!!
The aftermarket kits with hiems I've looked at are all running a shim/spacer...
Jduck said:
Someone with a lathe can make some in a matter of minutes.
Would be great! But I don't have access or know anyone close with one..
Machine shop wants HIGH $$$ wants to do a bulk run lol
Local shops don't have time for small project like that.. They said they would loose $$.
Re: Where to find shims/spacers for XP900 radius bars with heim joints???
Call Wide Open Design and talk to Rocky. They have them in their radius rod kits, I bet they would split the hardware out for you.
I can sell you some of mine. If you run 5/8 joints they will work. I have a specially designed spacer for the frame side that keep the hi clearance lowers from flopping back and forth and banging on the frame.
^^^ sent PM
