So i bought a 51 Whilly
well since my whilly is older i say you stole the color,,,, besides mustangs never came that color in that year:fawkdancesmiley:
mounted the fuse block, routed the bundles of wires where they are gonna lay more or less.
im gonna need to extend three wires as this harness was designed to mount the fuse block on the drivers side but that just wasn't happening.
Thanks to Mikey i borrowed the set of crimpers needed to make these kinda crimps. now its mostly hooked up.:D
attachment.php
few things i havent figured out yet like turn signals. i dont have a switch but i layed all the wired for em.
when i honk the horn the AC comp ind light lights :eeek:
im gonna leave the loom unwrapped till i get it running as i still have to wire in the engine transition.
headlights dont have power but tail lights do:flipoff:
Check out Ron francis wiring for a TS switch. They have one thats pretty simple and works well.
http://www.ronfrancis.com/
i need a turn signal switch as the brake lights are associated with them thru the switch in the harness i bought.
the other problem ill have is im all LED so turn signal flashers dont feel the draw to switch itself.
im just gonna hook up the brake lights using the turn sig wire in the rear for now. dont legally need turn signals:redneck:
Need Electrical Advice Here
Anyone know if this will work to connect the brake light circut and turn signals for the rear?
http://www.jcwhitney.com/directiona...ard-warning/p2005024.jcwx?filterid=c23252u0j1
or this one?
http://www2.cip1.com/ProductDetails.asp?ProductCode=C13-16-2101
thats how chevy has thier wiring, its even tied into the E flashers somehow.
i can mount it somewhere besides the column as i dont really have one.:D
the non LED light bulb indicators might be enough draw to make the flashers work... if not isnt there a different flasher you can just plug in that slows the flashing down?
