Turtle Bite
Wow, been super busy, but an update. I got the tranny in, and overall I love it. With the low-stall converter the motor feels much more "loaded up." It also made a huge difference in how the truck pulls- shift timing feels just right to me, not to early and not too late. The shifts are crisp but not harsh, which was very important to me. I did not want a sledpull tranny that bangs through the gears.
I have about 1500 miles on the truck so far, and got to tow my big trailer for about 250 miles. On hills where the old convertor would just slip, the new tranny will pull the trailer at whatever speed I want. My fuel mileage also went up about 1.5mpg (corrected), but I switched tires at the same time so I cant say what exactly made the difference.
I did run into a few minor issues, mostly my fault. When I first installed the gov pressure fooler box DTT sends I wired it in wrong, and the tranny went into limp mode (2nd gear start). After studying my FSM I eventually figured it out. The DTT instructions for this part were not the best.
I also couldnt figure out why the convertor wouldnt seat in the pump with the front face the 7/8" deeper than the bellhousing my FSM said it should. I really really wanted to be sure not to break the pump, so after looking around I found out that on the diesel 47RE the front face of the convertor actually sticks out approx 3/4" beyond the bellhousing and I was fine.
Finally, I need to adjust my idle up a little bit. With the low stall convertor and a cold motor, it has the tendency to stall because the motor drops to 550 or so when putting it in gear. Easy fix.
If I were to do it all over againg I would probably buy the DTT parts and have a local shop do it. The quality appeared to be excellent (tanny case was beadblasted, plugs in the ports, adjusted right out of the box, etc) BUT the turnaround time was like 8 weeks all said and done.
