My personal issue is more with tire size height than axle width.
Bigger tires make it easier, it's the little tires that tear up the trails.
I gotta be honest......
To make it clear......you've been told you can't use FS land (4x4 trails). How does that sit with you?
I gotta be honest.....you sound undecided and uninformed on what's REALLY going on here. Look closer, think deeper.:;
NO I am not undecided or uninformed.
So..... 80 + means FS and FW axles right?
Big assholes tear up trails. Little dicks try to restrict them. Get your facts straight.:fawkdancesmiley::redneck:
I was 81" with toyota axles and 15.5" wide tsl's at "street" pressure.
Thanks. I kinda forgot people run wider than a 13.5 ever. but am suprized still at 81" with Yota axles.
Oh and totally understand about PEOPLE with smaller tires tearing things up. Emphasis being people..... not tires size.
so dump the spacers and you are under 80. but without going to oldschool grave diggers no way to get you under 72" huh.
Our TJ's both measure 79 up front with adapters and 35-37's
Can take the adapters off one and make it 76.. other I am 78 till I new knuckles.
I gotta be honest I think FS FW axles is too big for the trails, and not just cause I am narrower than that. I would support the 80" width but would fight for a reasonable width to keep FS axles too.
I will make the statement again, the old rule is HUB to HUB, not outside tire to outside tire, My tires are well beyond my hubs and under the old rule I am well under the width limit even though my rig is 80" outside tire to outside tire, I do not know the wording on the new width restriction, but would be good to know before everyone gets in an uproar.
which map are we supposed to use?
They are both on the web site. and the new one is hard to find.
if you go looking for a map, the first one you come to mentions nothing of the restrictions.
http://www.fs.fed.us/r6/mbs/projects/travel-management/mvum_evans_cr.pdf
http://www.fs.fed.us/r6/mbs/local-resources/images/EvansCreekOHVmap.jpg
