fatguy7814
Is anyone running the Ford 8.8? Or have any opinions on this axle. Ran into some guys in Utah that swore by them. Seem to have good reviews. Toyota rear has got to go. I'm looking for a replacement.
fatguy7814 said:Thanks for the info! No trouble with c clips?
TBItoy said:4.3 and 39 reds.... just go with a shaved 14 bolt from the start. 8.8 would be a waste of effort and money.
muddinmetal said:Agreed! Or an 80 series rear if you gotta keep it toyota
TBItoy said:Considering he was thinking of swapping in an 8.8, I doubt that's an issue.
scrambled said:14 bolt would need to be narrowed, new shafts, shaved, and new wheels.
8.8 They can be had with 4.10s and disc brakes for $100-$200 around here. Width is close enough and you would need new wheels.
rednecklights said:I'd question why the yota rear keeps giving way.
wat locker? welded? spool? WHO set it up ?
Sent from my C771 using Tapatalk 2
TBItoy said:Cab chassis 14b is 63" wide.
By shaved, I meant just getting a 13bolt cover from Barnes or undercover fab. Not a full ring gear shave.
Hubs can be converted to 6lug.
But yeah. Disc brake explorer 8.8s are cheap.. I haven't seen one with stock 4.10 gears though.ever. always 3.55 or 3.73.
Another option would be getting a dirt cheap rear Dana 60 30 spline, and welding the ends of a Toyota housing on it to run Toyota shafts/brakes/etc...
