offroadguys
I bought a 1970 IHC scout 800A for $800. it has a 304 v8 with a T-18 and a dana 20. The rig from front to back is rusted out literally. Someone tried to hokey something up to hold the rig together (3/16 plate welded to the shape of the tub, but he didnt paint it so it began to rust) I have totally cut out the tub and welded ina new one. I have also built a new frame for the tub to sit on as the C-channel was completely rusted out. Most all body mounts were rusted out all but 3. two in the front and one in the back. someone had tried to hold the body on with a skateboard wheel and a grade 8 bolt. I Kept the bolt chucked the wheel. Another thing that was severely rusted was the tailgate. The whole bottom had holes in it. I bought some new tubing and bent some metal on a brake and rebuilt it. The front floor boards are a work in progress. The passenger side was totally rusted and I rebuilt it, as well as the driverside. This guy who owned it before me was remarkably stupid. How many know you cant fix rust with fiberglass? He tried to rebuild bothh the rocker panels with fiberglass. Another thing he jury-rigged is both of the gas tanks were glued in with exansion foam. A hour of fighting them, and they came out. I have pics of before i took it apart but I have to get them off of my pc into the link below.... But those pics are what I have for now.
Here are some pics from when I brought it home:
Factory articulation, sucks.
Plans are as follows.
SBC 350 on pane, or TBI'd I havent decided. SM465, with a Np205.
Dana 60 front 5:38's and a EZ locker. GM corporate 14bolt fullfloater with disc brakes, 5:38,s, and a detroit. Spring over and 39.5inch Superswamper TSL, Bias of course! I will also be adding power steering (a must). Aluminum radiator, and electric fan. Have plans to build some tube doors for it.
Pics can be seen here: http://img268.imageshack.us/g/p3040016n.jpg/
After I cut out the rust I started taking pics so this what I have.
After the tub repair:
Driverside floorboard before:
Front floorboards after:
