trail closures
what options on trail closuers (seasonal)
  • seasonal closure
    Votes: 16 34.0%
  • Tire size restriction
    Votes: 6 12.8%
  • special use permits
    Votes: 25 53.2%
  • Total voters
    47
Status
Not open for further replies.
Maybe have chainsaw certs multiple times during the summer and then have two full weekend work party's with a full set of wheelers ready to "work to wheel" We could call it the anual Work to Wheel Nachees work party.
We need a plentifull supply of certified wheelers. at least 100-150 to at all be succesfull next year. Those people that "work to wheel can also assist in breaking trail with the U.S.F.S to designate what trails should be open and when.
That may work if the chainsaw certs are till good for the next winter. There would need to be a work party on the opening day of wheeling in the spring to beat the traffic. I usually go snow wheeling on this day and there's usually not much traffic. I think the downed trees are only a part of the problem though.....
So you think this is a viable solution that we should bring up to the FS? Just let everyone bring their chainsaw without training and the trees will all disapear? How is this different from year past? How well did that work then?
I'm not trying to pick on you or your ideas but sometimes it helps to think things through.
I'm saying, I don't need the FS to clear or maintain a trail for me. If I want something clear and maintained I'll drive I-90. It actually has never been tried, the FS has always cleared trails. Got to keep people thinking you're useful and use your budget money. I think it's just fine that there are work parties to clear/repair trails. Are they necessary? Up for debate.
That is where this comes into play and instead of winter it would be "spring/fall routes" and "Summer Routes"
But to answer the O.P. question I think working with the F.S./D.N.R to Make two trails or a "Winter Bypass" through problem areas may be a good idea.
You have your summer trail "softer area" that would be used in the summer and winter trail "More Hardpan/firm area" This would alleviate damage and allow nature to "Heal".
We would have to figure out a way to block these alternate routes effectively but im sure there is a genious somewhere in this group that could figure it out.
Opening day puts us behind the power curve it would need to be the two weekends before.
It's necessary being that many people don't carry chainsaws....I know on DNR land they don't want you to clear trails without first getting the OK but from what I understand the FS has a different policy.
As an Amazon Associate we earn from qualifying purchases. Product prices and availability are accurate as of the date/time indicated and are subject to change.
There are no DNR trails in this area, just green dot roads which get blowdowns. They may not like it but there is no rule against cutting down timber. No different that cutting wood for a campfire.
You wouldn't be able to clear a whole trail, the higher elevations still have feet of snow, some trees are still buried. Would those trails stay closed even though there would be no damage because all the wheeling is on snow? Are you suggesting just clearing some low elevation, dry (can't have mud, ruts are made) trails for memorial?
Because restriction is an easy solution for the FS.
Which is exactly why I support the seasonal closure....The big problem is the transition when the snow melts off. This uncovers trees that weren't an issue before and when the snow first start to melt people tend to follow tracks in the snow. Tracks that were first made by a snowmobile then a wheeler followed those tracks. Snow's still deep so no harm no foul but then as the snow gets thin tires start getting into dirt.....off trail.....
Well if I couldnt make it could you? And if you can then why cant we just load up some chainsaws in your rig and go do some cutting? I am saying open as much as possible. whatever doesnt get cleared awaits some to clear it not necceserly a work party but await proper melt off and trail markins be visible.
Yes I know this. This thread is about FS trails. I brought that up so people would know not to do that on DNR trails..
So then should we have a rule, no wheeling on snow unless the whole trail is snow and at least 2 feet deep? By your reasoning some trails shouldn't be open until at least july as some of the higher elevations keep snow until then. Close them in early October as that's when the snow usually starts? So we wheel in August and Sept. Some wheel for the challenge of a difficult trail, there are no difficult trails in little naches/manastash in aug and sept.
Did you copy this from one of the other threads? I feel you've written this exact thing a couple times before.... Obviously it hasn't sunk in to most.........
They have that exact rule for snowmobiles...
That's so they don't get run over by a group of wheelers and it isn't enforced.:D
We need to start thinking as a whole right now and then think of indivuduals as we organize and progress.:awesomework:
It is enforced. Regardless, I vote for seasonal closures.
The Kaner Flats Massacre should have been enough evidence as to this reasoning. And obviously the F.C. took it as such.
As I understand it you only need the the saw card if you are participating in an official FS cleanup. You are not allowed to use a saw if you have the card beings you fall under their umbrella insurance policy.
Yes something like this...The trails could be closed on a case by case basis and would only need to be closed for a couple weeks each then opened back up. Say for instance snow starts lake October for Shoestring and melts again early May. Close it for the last week in October and the first week in November then open it again until snowmobile season. Same thing in the spring, close it last week of may and first week of July then open it back up....Maybe during these closed weeks we could do work parties so it's good to go once it opens?
I didn't copy it but I have said and written the same thing many times before....Glad someone is paying attention!:awesomework:
Also to shed a little light on current events it may help to know that the new Ranger for Naches is a woman who's favorite past time is taking pictures of flowers and crap like that....I'm guessing that running over the flowers doesn't rub her in her G spot.:rolleyes:
This is taken from the Evergreen Mountain Bike Alliance, an ORGANIZED, (key word there, something this group can't figure out) A group that is DOING something, instead of camping out at a keyboard saying "we need to ban to gether and fight the man!" Theyre actually getting things done. I for one will side with them any day of the week before i join a 4x4 club. They are organized. Their heads aren't in the clouds. If you want to "ban together", join this group, instead of making 16 other smaller ineffective groups that do nothing.
They got things done.
Naches Ranger District - Trail Closure Update
Many mountain bikers have expressed concern over the last few weeks about proposed seasonal trail closures within the Naches Ranger District and we want to provide you with an update.
Evergreen has been working with the Naches Ranger District on your behalf and has clearly communicated the concerns of our community and the science behind mountain bike impact on trail conditions. As a result, the Naches Ranger District has indicated to us that mountain bikes will not be subject to these seasonal trail closures.
We applaud the Forest Service for this significant decision which reaffirms their understanding that mountain biking is an activity which is most similar to hiking in its impact on trails. Evergreen will stay in communication with the Naches Ranger District on this issue and will keep you informed of new developments as they happen.
Status
