Chris's toy (Sandtrap1986)
I got a bunch of boxes today with half being my electrical supplies to restock my inventory and the other parts Chris ordered for the truck.
So since I had material to build the last cable to the starter.
So at this point all needed factors to make it run are there. I turned the (broken) ignition switch and no crank--damn. So I spent some time going back over the start system and found where I had made a mistake.
When I bypassed the clutch start switch I connected the wrong 2 wires. I had connected the Black/red to the Black/yellow. The correct way is the Black/red to the White/black. After that it cranked so I threw a gallon of fuel back in the tank and the damn thing started and ran.
Very nice Mike!!!!Get that Biatch ready for some wheeling!!!!:awesomework::beer::beer:
I got Dave from D&J working on some rear disk swap mounts if anyone has the Info on the brackets or one they spare so we can copy I would appreciate it
Hard to say--short run but it didn' sound like it was missing or knocking--so forward I go....
So here is the stock thermostat housing/upper radiator neck assembly.
The configuration of the neck and radiator was going to make getting a hose to fit a pain. Well I formulated a new idea why not make the neck so an easier hose could be sourced and just basically make a better setup.
This ended up being a lil bit of work to get everything where it needed to be. One nice aspect for modding the OEM neck is the fact its steel with the base being 3/8" thick so welding to it without causing any warpage will be a piece of cake. I ended up using 1.5" tubing which is perfect since the hole in the base is roughly the same ID as the .120 wall tubing ID and the neck on the rad is also 1.5"--It all just seemed like a perfect match.
But here is what I came up with.
So the last few days have been slow going but I was able to get more stuff done.
I pulled the rad and I was not happy with how it sat--I wanted it a tad over more to the passenger side due to the clearance from the rad to the nut on the steering box. Well I ended up working the mounts and made a 1/4" spacer for the rad and I was able to get it where I feel comfortable with it.
So in stock form(4.3) the trans cooler lines went down the motor. Due to how close the Y pipe will be to the pan I wanted the most room for the cooler lines from the heat and the only way was to run them down the frame rails.
So I ran rubber from the trans to the lines I made on the frame.
