Wide Open Design/EMTS Revolution Build
More parts, Carrier Bearing, Winters shifter from WOD. Spools from ECGS and ECM mount from Binksfab
after taking a better look at the picture and the new pics posted, i believe the carrier bearing you are running will be a solid piece for you, imo.
wizzo said:
will they let you exchange that carrier bearing for the "ultra" design? if so, do it
[/quote
I actually asked Adam about the Ultra Carrier and he said it was for mainly high speed/high hp rigs. He said this carrier should handle anything Ill be doing. I sure do like the way the Ultra looks though.
more junk Orbital came from 1tonrubicon on here. TG battery box. Column and U joint from Woodlee
Rolled outside to knock dust off
Thanks Neal. Besides moving the alternator it also moves the Pump to the head. Its very tight at full bump. I might have been able to use some stock fbody accessories but this just looked badass and simplified things a lot.
The Buggy is looking awesome & this is a great build thread! There is just something about the Wide Open Chassis's that catchs your Eye!!!
Heres a better look at the carrier bearing, same as whats in WFO
Update way overdue. Been working pretty steady on it. Offroadwerks has done a good bit of work to it at his shop. Its now currently at a buddys hot rod shop getting aluminum work, floorpans, firewalls and skins. Heres a pics because nobody likes to read.
how about some parts. 1350 hd front driveline kit from EOR, local guy built the fuel cell holder, engine oil and trans coolers
Crane Knuckles, Yukon Chromos and superjoints, Ruff Stuff lights
more goodies LS6 intake and injectors, OCX speakers and 12voltguy switch panel
PSC reservoir, Wide Open Design fuel system and coolant hose kit
more tubework courtesy of Offroadwerks
