Cutting axles.
stealthrunner1
Western Wa.
Need to find somebody before labor day weekend say between now and then to cut down some axles for me.....no resplineing just cutting material off the ends... any info?????:eeek: Or does any body know if randys can cut axles???:eeek:
I got and absive chop-saw. Or a 4.5" cut-off wheel works just as well. Don't thin I want to use the dry-cut saw however, pretty sure a hardend shaft won't be good n the blade.
A 4.5" cut off wheel works great....only takes a few minutes per axle. Put a little chamfer on the end with the flat of the cut-off wheel then de-bur with a wire wheel.
Thanks guys ...was just a little leary of taking a cutoff wheel to them...doesn't the cutting mess with the heat treat??? The one i need to trim half inch from is superior Evo. but the short side they sent must be kind of a universal short side for two lenghts...every thing lines up exept the splines are a half inch too long.. then the rears are yukon cut to fits....just for your info...:;:beer:
