Little Gibby's 45 MB
I believe so. I ordered and sent you one a while ago. IIRC, we have an edlebrock manifold on there and that should have fit.
I know we are both getting older and this has been going on for a LONG time... but I recall you test fitting it and saying that it would work.
Looking at the pic of the installed motor, there's already a thermostat housing on there :confused
Ya the one there is pretty rusty and pitted...
If thats the one then its not the right one and I vaguely recall saying it was and was never ordered...
I still have the last stash of parts to go thru but I really remember it not being ordered..
If you cannot find it, I guess I will have to order it.
Parts list
Is one of these water necks, the right one?
http://www.summitracing.com/parts/sum-371100/applications
http://www.summitracing.com/parts/sum-371101/applications
This hold down clamp appears to be for the correct engine.
http://www.summitracing.com/parts/mrg-1009/applications
Having a tough time finding a kit for upper lower and heater hose. I did find these but I don't have the measurements to get the right sizes.
http://www.summitracing.com/parts/spe-68188
You didn't ask for one, but I assume an overflow tank is needed.
http://www.summitracing.com/parts/spe-4179/overview/
Heater hose?
http://www.summitracing.com/parts/spe-39606/overview/
Heater hose?
Neither of those necks will work--only one I found was the one I pm'd ya. (very unique neck).
Hold down won't work..
I will spend a couple days at the parts store and see if I can come up with a rubber hose option first..
Hard to tell with the coolant tank without the nose being in place...
Got the slider/steps bent up...
I cannot find a way to order those parts from TA motorsports. Their website stinks. I'll have to call on Monday.
I like those hoses. I just wish I could find a kit that has the upper lower and heater hoses all in one.
This looks like it might work. Just need a lower hose to go with it.
http://www.summitracing.com/parts/spe-7718/overview/
Got one side done.. Other slider is ready just gotta notch the tub (taken longer to do or both sides would have been done)
Got some goodies so time to get more done. Will be running the same spal fan i am since i know its a great unit. This time i found the part number for the rubber gasket. Pulled the rad and got it mounted up.
I hate cable. Was hoping this was mounted when it came back but i took care of it..
Rad is vack in for good.. Next will be diving into belts and hoses and brake lines..
Here is a similar swivel.
The ones we use are heavier duty than these and have no pins but closed eyes that are just as compact instead.
